beta11_lock-ups
Posted: 03 Feb 2006, 23:35
by cpb
been having unusual lockups when
opening files on the network or
when dragging a file from salamander
to another app. problem is not readily
reproducible though.
never experienced this problem with
older versions.
will try to pin-down a reproducable case.
other informations:
O.S. win xp pro 64. sp1
4G Ram
dual dual-core opteron 280.
-cpb
Posted: 03 Feb 2006, 23:55
Is Servant Salamander definitely freezed?
Could you start second instance and using menu Help > Task List break the freezed instance? Bug report should be generated in the freezed instance...
These problems are often caused by faulty shell extensions, please look at http://www.altap.cz/salam_en/faulty_she ... sions.html for more information.
Posted: 14 Feb 2006, 21:56
by cpb
yep it was an extension problem, an
error can be generated if I switch off
salopen. using salopen can cause a
lengthy delay as described.
an error report has been emailed.
problem does not occur at all in explorer,
so I have to use that for now.
Posted: 14 Feb 2006, 23:14
Could you uninstall the faulty shell extension?
Please send me email with the bug report again and insert link to this thread, I will check it.
