Find, hide and position
Posted: 23 Feb 2009, 13:48
				The cursor position in Find is strange after hiding files.
I try:
- search for (find) a long list of files and folders
- go to position 20 or so
- select that file and up (Shift-Ctrl-Home)
- hide (Ctrl-H); the first file (of folder) is selected afterwards (position 1)
- press Shift-Down (or Shift-PgDn)
The selection seems to start at position 20 now, which is strange. If I press Down, Up first and then start using Shift, everything works like expected.
If after hiding less than 20 files and folders exist, the selection starts at position 2 after Shift-Down.
This has been true for quite some versions of Salamander.
I tried to look for similar postings, but searching for Find returned nothing at all!?
			I try:
