JSON Viewer Plugin
- stepand76
JSON Viewer Plugin
JSON Viewer is viewer for data in JSON (JavaScript Object Notation) format.
Plugin is available here:
http://sites.google.com/site/stepand76/asplugins-enu
You can discuss the plugin in this thread.
Any comments, suggestions and feature requests are welcome.
- stepand76
Version 0.2.0 (28.1.2009)
[-] Fixed memory leak when showing of data from clipboard.
[+] Texts moved to SLG file (now it is possible to translate plugin to other languages).
[+] Added version information (VERSION_INFO) into plugin binnary files.
[+] Added plugin icon and icon of viewer window.
[-] Fixed placement of viewer window.
[-] Fixed showing of message dialogs (icon, set of buttons).
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancementhttp://sites.google.com/site/stepand76/asplugins-enu
- stepand76
Version 0.3.0 (4.2.2009)
[+] Added compatibility with AS 2.52 beta 1.
Legend
[*] Change
[-] Bugfix
- stepand76
Re: JSON Viewer Plugin
Version 0.4.0 (24.8.2009)
[*] Fixed compatibility with AS 2.5, 2.51 and 2.52 beta 2.
[-] Fixed Alt+Space navigation in viewer.
Legend
[*] Change
[-] Bugfix
- stepand76
Version 0.5.0 (23.10.2009)
[+] Added the "Focus" command (F) - focuses the file in the panel.
[*] JSON Toolkit 1.1.
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancementPlugin is available here:
- stepand76
Version 0.6.0 (4.3.2010)
[*] Built with Delphi 2010.
[+] Enhanced "About" window.
[+] Added an option to save possion and size of viewer's windows.
[+] Added an option to prefer keyboard shortcuts in main menu.
[*] JSON Toolkit 1.2.
Legend
[*] Change
[-] Bugfix
[+] New feature, enhancement- Attachments
- jsonviewer_0.6.0.zip
- (722.26 KiB) Downloaded 3661 times
I noticed that all tree entries are editable. Or at least, they look like that: just click on the active entry and type some text. Nothing is stored of course.
Should it be readonly?
- stepand76
Yes, it should be. Thanks for the info.mdruiter wrote:Should it be readonly?
I tested it with AS 2.54, but I get "Error parsing JSON data" on all the files I try...
Hugo Ahlenius
Hugo Ahlenius
- stepand76
It works for me, please provide a one.
It's failing to parse the data because the it's not valid JSON (although it seems it's a valid JS object literal). If you look at http://json.org/, you'll see that JSON allows only double quotes to enclose strings and keys in objects have to be strings too.
Looks like the viewer does not work if the root element is not an object. My .json files have a list at it's root and only show the "JSON" tree root in the viewer.
Am I missing something?
The files have been downloaded from the codeplex archive, e.g. https://archive.codeplex.com/?p=visuallogparser.
I am using JSON Viewer Plugin Ver. 0.6.0 downloaded from this thread on AS 2.54
Looks like the plugin does not work for Altap Salamander 4.0. I get this error when I try to add the plugin:
Is there an updated version available?Unable to load plugin (<path>\plugins\jsonviewer\jsonviewer.spl) or some of its components.
Error: (1400) Invalid window handle.
See plugin details in menu Plugins / Plugins Manager.
