				Scrolling with trackpoint isn't working
				Posted: 11 Dec 2008, 13:03
				by salajack
I use Salamander a lot on my Laptop.It is an IBM thinkpad. Everything works well so far except the scrolling in the left or right file panel with the thinkpad trackpoint .
I don't like the touchpad, it is less productive than the trackpoint
It would be great if I could know if this is an error.
				Posted: 11 Dec 2008, 17:18
				by Ether
				Hi. Does the trackpoint work in other applications, e.g. Windows Explorer? Has it been always that way or did scrolling stop working at some point?
				Posted: 11 Dec 2008, 18:39
				by salajack
yes it runs with every other application.
				Posted: 11 Dec 2008, 19:05
				What Windows are you using?
				Posted: 11 Dec 2008, 19:47
				by wosa
				Hi, Im using Lenovo R400 and TrackPoint and TouchPad works great.
OS: Windows Vista Bussiness
Some people have problems with scrolling pages in Opera browser. It could be fixed by downloading new drivers for UltraNav (TrackPoint+TouchPad).
Try
http://www-307.ibm.com/pc/support/site. ... eLenovo.do and there is a link: "Automatically download and install drivers". I hope that this will work.
				Posted: 11 Dec 2008, 22:01
				by Ether
				@ALTAP] I think it would be a good idea, if you programmed a small testing application that would display all WM messages received (I couldn't find any and I don't have the knowledge to create it myself). That could show us why the trackpoint isn't working properly.
				Posted: 11 Dec 2008, 22:02
				Posted: 11 Dec 2008, 22:24
				by salajack
				HI,
I am using windows XP SP2.OK, I will have a look, if the new driver helps. That's a good idea.
Thanks
				Posted: 11 Dec 2008, 22:55
				by salajack
				YES, the latest and greatest driver did it
I thought we already have it as standard.
Have nice night
jack
