Could you please add a button that allows me to "flat" a directory structure, that is to display all the files inside the current directory and its subdirectories?
Thanks
Flat view
Re: Flat view
While it's not possible now. You can try rough workaround, and find *.*. In result you get all files in (sub)dirs in one view. Just a workaround...costa wrote:Could you please add a button that allows me to "flat" a directory structure, that is to display all the files inside the current directory and its subdirectories?
Thanks
Jiri {x2} Cincura
Try Find Shift+F7, select all Ctrl+A, copy Ctrl+C, create somewhere temp dir F7, create shortcuts Ctrl+S, thumbnails Alt+F5, go to shortcut file Ctrl+T
česky tady
česky tady
Am I missing something here? PictView doesn't seem to display thumbnails for image shortcutsk0nelupy wrote:... create shortcuts Ctrl+S, thumbnails Alt+5, ...
Later: Ah! I have to use my Explorer Thumbnails plugin
Find is Alt+F7 of coursek0nelupy wrote:Try Find Shift+F7, select all Ctrl+A, copy Ctrl+C, create somewhere temp dir F7, create shortcuts Ctrl+S, thumbnails Alt+F5, go to shortcut file Ctrl+T
česky tady
