Sequence Listing
scorpes
Sequence Listing
Post by scorpes »
Hello, I don't know if this already exists but I would like to have an option to turn on sequence listing so it lists a sequences as one file.
As example you have these files in a folder:
I want this to be listed like this:
MyFile.jpg 1-5
And maybe with an option to collapse or expand the file.
I want this because i work with a lot of files, sometimes i have more than 8 sequences with 1000 files in one folder. And when i need to copy one sequence to another folder than I'm doomed :P
Is this possibe?
You are not doomed. You can use the Select command to select all files from the sequence. Just hit + on the numpad and enter MyFile.* and confirm.
scorpes
Post by scorpes »
Oke that's cool! But it would be easier for me if I have a overview of the sequence lists in a folder.
Tip: use directories...
Jan Rysavy wrote:Tip: use directories...
:shock: I coul not resist :mrgreen: :lol: :lol: :lol:
scorpes
Post by scorpes »
Using directories is not an option... because we need all sequences in one folder because it's easier for the application we are using...
