Fast Method of Switching Viewers?
Posted: 05 Aug 2008, 16:50
by dprice
We have many .TXT files that are tab-delimited that show up perfectly using the Database plugin. Unfortuntely, regular text files (readme.txt, etc.) do not show up very well at all. Is there a way to quickly switch between the two? Changing file extensions is not an option due to the production process here.
Thanks,
Derek
Posted: 05 Aug 2008, 22:32
by Raptor
Ctrl+Shift+F3
or
Files > View With > ...
Posted: 05 Aug 2008, 23:06
Look at Options > Configuration > Viewers & Editors > Alternate Viewers.
You can define alternate viewers there. Use Ctrl+Shift+F3 (instead of F3) to activate these viewers.
Posted: 06 Aug 2008, 15:08
by Guest
Is there nothing that AS can do?!
Thanks,
Derek
