PDF icons not displaying
Thunesier
Post by Thunesier »
In Salamander 2.51 the icons for PDF files don't display properly in the detailed view on folder contents. I remember that shortly after installation of Acrobat 8.1.2 Professional, they did display correctly. The icons for all other file types are being displayed correctly (see attached screen shot).
I am not using the 'Use simple icons' drive options, I have re-read associations, increased the icon cache size to 2000 -- no help.
This is under Vista Ultimate w/SP1.
Any ideas?
screen shot of folder view
cincura.net
Post by cincura.net »
View in Explorer is OK?
Jiri {x2} Cincura
Thunesier
Re: View in Explorer is okay.
Post by Thunesier »
Yes, the PDF icons do display correctly in Explorer (see attached screen shot).
Folder view in Explorer
Tim
Post by Tim »
Try and repair Acrobat.
It solved my problem.
Cheers
Tim
Thunesier
Post by Thunesier »
Tim wrote:Try and repair Acrobat.
Cheers
Tim
Mine, too.
Thanks for the hint!
Konrad
