RENAME plugin
Posted: 19 May 2008, 17:48
by Youri42
Good afternoon,
I have a question concerning the rename plugin of salamander : I use quite often the rename plugin to rename a definite format into another. But neither of both format changes. So the renaming action never changes. But between two uses of this particular batch I use very often the rename plugin for other purposes. Too many, so they don't stay in the history of salamander.
Since it is a quite complex batch to rewrite it each time, I have save the script in a file. But is there a way to save some specific batches in the rename bach window or menu ? (like custom)
The script is :
  • -> search for : (\d\d)(\d\d)(\d\d\d\d) (\(\d\d\.\d\d\.\d\d\ ..\))=(.*)=(.*)(\(.*@.*\))\.eml
    -> replace with : $3-$1-$2 $4 - $5 $7.eml
Thanks in advance for your answer.
Youri.
Posted: 19 May 2008, 20:14
by Ether
There are many planned enhancements to this plugin, including a list of favorite settings.
@Lukas Cerman] How's it going with the new features?
Other requests: http://forum.altap.cz/viewtopic.php?t=48.
