If I'm using administrative UNC share like \\server\c$\SubDir, I can't drag and drop files, also copy and paste doesn't work. All action are done in the same window and from a subdir to the parent dir.
I'm using Vista with Win2003 and AS 2.51.
Could you verify?
Thanks
Problem with admin UNC Share
Re: Problem with admin UNC Share
Are you running AS in admin mode or as normal user?Eric wrote:If I'm using administrative UNC share like \\server\c$\SubDir, I can't drag and drop files, also copy and paste doesn't work. All action are done in the same window and from a subdir to the parent dir.
Jiri {x2} Cincura
