Thumbnail view + no PictView plugin = confusion
Posted: 26 Mar 2008, 04:06
Without PictView installed there are no thumbnails of images available.
The manual misses the info about the necessity of PictView (or other appropriate plug-in) to see thumbnails of images.
Also it should be distinguished between computed and embedded thumbnails. The manual does not say directly about the difference.
(use integrated HELP search feature and search for "thumbnail" no quotes)
Altap Salamander: Working with Windows and Panels
:::: Selecting Current View
Is there a way to fix this? (Windows explorer does the thumbnail view natively)
