fast browse with arrows
Posted: 27 Feb 2008, 15:15
by lumega
i'm user what find alternative of FAR MANAGER. It was great software.
Now i try SALAM. In it not so fast browse file system. Because of not working arrows (left, right) in files list.
left - top of list
right - bottom of list
Make it please.
Re: fast browse with arrows
Posted: 27 Feb 2008, 15:54
by cincura.net
lumega wrote: left - top of list
It's not a good proposal. Left/Right arrow have the meaning when you're using i.e. thumbnail view.
Posted: 28 Feb 2008, 12:15
by lumega
i say about DETAILED VIEW of files.
in it cursor work only by UP, DOWN, PGUP, PGDOWN.
i want also LEFT, RIGHT.
Posted: 28 Feb 2008, 12:30
by lumega
Also HOME, END not work?!
Posted: 28 Feb 2008, 13:01
by lumega
It's bug: HOME, END sometimes not work.
Posted: 28 Feb 2008, 19:14
by Ether
In Detailed view, left and right arrows are used to move the panel left and right (when the columns don't fit in the panel). Also when editing command line or when in search mode, the meaning of the keys (including 'home' and 'end') are different. Otherwise 'home' and 'end' keys work just fine. Could you describe the bug in detail? When don't these keys work, what were you doing? Maybe a screenshot would help.
Posted: 28 Feb 2008, 20:58
by lumega
nothing special, it happens randomize,
maybe because of external editor (notepad++)
Posted: 29 Feb 2008, 11:08
by lumega
ether wrote:In Detailed view, left and right arrows are used to move the panel left and right (when the columns don't fit in the panel).
I think that not right. For moving panel better use CTRL+ARROW, or SHIFT+ARROW.
