Character (unicode) support problems
Posted: 21 Jan 2008, 10:35
by Mindaugas
I'm from Lithuania, Baltic char table. We have letters like ė, ų.
So, If i have folder name containing these letters, altap is giving read error.
Posted: 21 Jan 2008, 10:38
by Guest
Oh and more, When filtering, I'm missing customizible filter presets. Now you can choose only no filter, or fill text box.
So, if i'm cleaning files, i would like to switch between filters.
Thank you
Posted: 21 Jan 2008, 17:05
by Ether
filter] You can choose from previously used filters in the drop-down menu.
folder with non-Latin characters] As you probably already know (judging from the topic subject), this issue is connected with Unicode. Altap Salamander doesn't support Unicode yet, but it's planned. Look at
http://forum.altap.cz/viewtopic.php?t=2 ... ht=unicode for more informations.
Please, follow the
rules:
Jan Rysavy wrote:1. Search and read the forum before posting. Many of your questions have been already answered. To minimize post redundancy, search the forum and other relevant sources. Forum supports searching in existing posts using keywords.
2. Post one bug report, feature request, or suggestion per report. This makes it easier to follow-up on later and keep the thread focused on solving one particular issue.
3. Post your bug reports, requests, and comments into the appropriate Forum section: Problems and Troubleshooting, Feature Requests, and General Discussion.
