The copy path to clipboard function
Posted: 20 Nov 2007, 10:34
by hrc
It is a useful feature that I can right click and copy the entire or a partial path to the clipboard.
But, on network drives, I'd prefer it to copy the UNC path, "\\monster\data\source" instead of "F:\Source". My colleges may not have the drives mapped the same way.
Re: The copy path to clipboard function
Posted: 20 Nov 2007, 10:38
by KNUT
hrc wrote:It is a useful feature that I can right click and copy the entire or a partial path to the clipboard. But, on network drives, I'd prefer it to copy the UNC path, "\\monster\data\source" instead of "F:\Source". My colleges may not have the drives mapped the same way.
Use CTRL+SHIFT+INSERT (See the Edit-menu for all options!)
Did it do that?
Posted: 20 Nov 2007, 11:03
by Guest
The functionality was already there, fine.
When "copy to clipboard" on network drives I still think it should copy the UNC path. That way there's no uncertainty.
Using the <shift+ctrl+insert> shortcut I may have discovered a minor flaw. If I select a path and click on a file or directory before pressing <shift+ctrl+insert>, the path and filename is correctly copied onto the clipboard. Now select another network path. Using <shift+ctrl+insert> again, the previous path is pasted until a file or directory is selected. More logically it should copy the path with the filename.
BTW. I was a Salamander fan even before they began writing it! Beat that!
Re: Did it do that?
Posted: 20 Nov 2007, 11:05
by hrc
The guest was I
