using variable in Hot Paths
Posted: 20 Nov 2007, 02:21
by lanux128
is it possible to use environment variables in Hot Paths?
e.g.
$USERPROFILE\My Documents
instead of
C:\Documents and Settings\<username>\My Documents
Posted: 20 Nov 2007, 13:54
It is not possible, I will send this post to the Feature Requests section.
Posted: 29 Jan 2008, 15:00
by frax
+1
I would also love to be able to do a change directory to a environment variable, such as %temp%
/Hugo
Posted: 29 Jan 2008, 20:02
by Ether
+1
I'd like it too, but I think it's already implemented in AS 2.51.*
Look at
http://forum.altap.cz/viewtopic.php?t=365 (in Czech).
edit] Oh, that doesn't include Hot Paths? So, +1 stays, the rest is probably not true.
Re: using variable in Hot Paths
Posted: 27 Aug 2009, 02:45
by vld
+2
But seeing how long this has been requested, looks like I need to create a workaround
Posted: 28 Aug 2009, 09:53
$(WinDir), $(SysDir), $(SalDir), $[EnvironmentVariable] variables will be supported in Hot Paths from AS 2.52.
Thank you for your ideas!
Posted: 28 Aug 2009, 10:52
by thomas
Is it possible to integrate a help function and a link to the help file for these environment variables. Not everybody knows the environment variables. (for example: %PROGRAMFILES%, %COMSPEC%, %SystemRoot% ...)
Posted: 28 Aug 2009, 14:09
by KNUT
Jan Rysavy wrote:..will be supported in Hot Paths from AS 2.52...
Thast mean
not in the beta version?
