Viewer for DOCX (word 2007)
Posted: 14 Nov 2007, 20:32
Is there any possiblity to update the viewer plugin, so that I can view Office 2007 files?
Many thanks.
Mihai
Many thanks.
Mihai
Can you send us few sample files to support{at sign}pictview.com?finalfrontier wrote:Is there any possiblity to update the viewer plugin, so that I can view Office 2007 files?
1) Viewers must be tested on real-world data. For something with as wide definition & use as office file format is there is never enough test data.SvA wrote:I doubt some sample files will bring you any much further.
Thanks for the links.SvA wrote: What you probably need is the file format's definition Standard ECMA-376 Office Open XML File Formats or a converter like e.g Novell's OpenOffice OpenXML Translator
The docx, xlsx, etc. files are just ZIP files with XML (and some other) files in it. There's no thumbnail by default.Jan Patera wrote: 1) Viewers must be tested on real-world data. For something with as wide definition & use as office file format is there is never enough test data.
2) For many file formats I am able to extract at least a thumbnail without ever having any format specification. An example from the last week is the CKD file format used by CAD Keycreator (to be supported in Salamander 2.51). Another example is the OpenOffice file format.
Are you saying that there *can* be a thumbnail? Can you send me few such samples, please?cincura.net wrote:The docx, xlsx, etc. files are just ZIP files with XML (and some other) files in it. There's no thumbnail by default.
As I said before, I need real-world documents, not just "Hello world, this is my test file". I am sorry, but I am not willing to invest that much money for few files.roman2 wrote:Jan, wouldn't it be more efficient if you got hold of your own copy of Word 2007 and created all kinds of sample files you want?
AFAIR the option is there. But not sure, how the applications doing this. I.e. for Word there isn't, neither for images in document.Jan Patera wrote:Are you saying that there *can* be a thumbnail?
I can send you bunch of these files. Just send me private email.Jan Patera wrote:Can you send me few such samples, please?
Jiri, I mentioned the address in my 1st response in this thread. And I am pretty sure you already know it - support{at sign}pictview.comcincura.net wrote:I can send you bunch of these files. Just send me private email.Jan Patera wrote:Can you send me few such samples, please?
At least some information is needed to have seamless integration in Salamander, for example in the Thumbnail view...roman2 wrote:Considering that there are free MS Office file viewers available, why duplicate this functionality in this plug-in?
Thanks, Jan. I have found a thumbnail just in all but one .PPTX files (I assume these are PowerPoint presentations).Jan Rysavy wrote:Some DOCX samples: http://openxmldeveloper.org/articles/De ... ntent.aspx
If you associate DOCX to IE Viewer and try to do F3. The IE Viewer just offers you to download/open the file. It's not opened.Jan Patera wrote: However, may somebody, who has MS Office 2007 installed, please try to view any .DOCX file using the Internet Explorer Viewer plugin in Salamander?
It is possible (and I'd like to find out) there is a MSIE plugin automatically installed with MS Office 2007. Thanks
