Help With Find Files And Directories Dialog Box - RegEx?
Posted: 11 Nov 2007, 13:26
by knightball
In The Help File Under Dialog Boxes Expanded -> Find Expanded -> Find Topic When you click on Help from the Find Dialog Box After Clciking on Commands -> Find Files And Directories, it states that there is Regular Expression Check Box (11th Italicized) Section Down).
I do not see this check box for Regular Expressions anywhere on the dialog box.
Does any know how I can use RegEx in the Find Dialog Box (Most likely the Named: Text Box)
This would be of great help.
TIA
knightball
Posted: 12 Nov 2007, 09:53
Did you click the "Search file content" option?
