Shortcut for Quick Rename in the actual line (no new window)
Posted: 28 Jan 2006, 13:40
by Tim
For ages I've been looking for a shortcut to do a Quick Rename without opening the Quick Rename window.
I want to rename the file in the actual line (no change of position, no eye movement necessary).
I don't want the Quick Rename window to pop up.
AFAIK, the only way to achieve this is to click on the file name.
But I _do not_ want to use my mouse.
Has this shortcut been implemented yet?
Does anybody have a solution?
If not, can you please implement a shortcut for this?
Many TIAs
Posted: 28 Jan 2006, 15:36
by cincura.net
Configuration > Panels > Rename by slowly clicking the name twice
But you have to use mouse once.
I think F2 dialog isn't so bad and so work slowing.
Posted: 28 Jan 2006, 16:47
by Stefan
This F2-popup window is not bad for me, ..yes sometimes if i come back from
other file manger (sorry Jan
) it wondering me a lil bit for the first times
But we have the advantage to use older names to modify and reuse (to bad i didn't use that.)
My feature / improvement request would be
to highlight the hole name (in the "F2 popup dialog") without the DOT and the extansion.
i.e. highlight the
_____________
NamePart.ext |
only.
I gues the most times we rename the name part only
and let the extension be the same ?
Posted: 29 Jan 2006, 10:30
by Branstrom
I'd want the seamless version too, like the thread author... Poll?
Posted: 29 Jan 2006, 11:18
by Tim
Thanks for all replies, fellow SS Users!
So there seems to be no solution yet....
Dear SS Team: Could you please implement a shortcut for this?
Thanks a bundle!
Re: Shortcut for Quick Rename in the actual line (no new win
Posted: 30 Jan 2006, 10:37
by KNUT
Tim wrote:I don't want the Quick Rename window to pop up.
Sorry, but I don't understand your problem: What's wrong with the pop up window?
Posted: 30 Jan 2006, 12:01
by Tim
@ KNUT:
I prefer to look at exactly the same position when changing a file name.
The Quick Rename window opens at a different position.
Frequent eye movement is tiresome when renaming lots of files (in a process that is too complex to be automated).
Furthermore, when renaming in the actual line I can determine font and font size. This is not possible in the Quick Rename window.
Hope this serves as a little explanation
Posted: 30 Jan 2006, 12:41
by KNUT
Tim wrote:@ KNUT: I prefer to look at exactly the same position when changing a file name.
Yep - thanks
Here's my Tip for a workaround: Use the Renamer-Plug:
- Mark all the files to rename
- Start the Renamer Plug-In (via menu or CTRL+SHIFT+R)
- Select the "Manual mode" (ALT+L)
- Know you've your files in a smart list to edit the names.
- Customize the display Font under: Options - Advanced
Perhaps this helps... (or is it actually better than your desired feature....
Posted: 30 Jan 2006, 16:41
by Tim
Wow. Neue Perspektiven eröffnen sich!
Thanks very much for that incredible hint.
How come I've ignored the Renamer Plug-In for so long ... ?
Best wishes
Tim
Posted: 30 Jan 2006, 16:56
by Lukas Cerman
And even
-you can set your favorite text editor in Options - Advanced
-and by pressing F4 in manual mode edit your filenames in your editor
Or if you want automatic rename. Press F5 in manual mode and filter your filnames through a shell command. (the old names are pushed to stdin of the colon you write and the new are read from stdout).
Posted: 30 Jan 2006, 17:39
by Tim
Mind-boggling!
....and I really thought I knew this program.
....and I really thought I was productive.
....and I really thought I was effective.
You live and you learn.
Thanks, guys!
Posted: 30 Jan 2006, 18:13
by Stefan
very nice to have this forum (and sala of course)
thank you Lukas.
