uninstalled, but cant delete salamext.dll
Posted: 01 Sep 2007, 04:27
by chimpoo
i uninstalled the program because i had no need for it anymore
but
it left behind a folder named plugins
inside is salamext.dll
i tried to delete it, wouldnt work
i restarted comp many times
and tried deleting it without having explorer.exe running
nothing
please
someone help
btw, this product is good other than that
Posted: 01 Sep 2007, 17:55
Hello, it looks like uninstaller didn't unregister the shell extension. How Did you unistall Salamander?
Workaround:
1. unregister salamext.dll shell extenstion using command: regsvr32 /u salamext.dll
2. rename salamext.dll to (for example) salamext._dll.
3. restart Windows
4. delete salamext._dll
Posted: 01 Sep 2007, 19:11
by Guest
thanks man
ill try that right now
and i uninstalled through the add and remove programs
Posted: 06 Sep 2007, 22:13
by zarevak
Jan Rysavy wrote:Hello, it looks like uninstaller didn't unregister the shell extension. How Did you unistall Salamander?
Workaround:
3. restart Windows
Shouldn't you unregister the Shell extension manualy before removing it? Manual uninstallation:
Posted: 09 Sep 2007, 20:40
zarevak wrote:Manual uninstallation: regsvr32 /u salamext.dll
I will update my post, thank you!
