Unhandled win32 exception
Half-Death
Post by Half-Death »
Hello,
I've encountered another application error. I thougth it was TortoiseSVN (I'm using 1.4.4 r9706), but this time it looks different.
The minidump follows.
Microsoft (R) Windows Debugger  Version 6.7.0005.0
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\work\SALAMAND.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: SRV*c:\windows\symbols*http://msdl.microsoft.com/download/symbols;C:\windows\symbols
Executable search path is:
Windows XP Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: SingleUserTS
Debug session time: Wed Aug  8 14:46:00.000 2007 (GMT+2)
System Uptime: not available
Process Uptime: 2 days 5:33:44.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
eax=02c276d0 ebx=0017db20 ecx=9f3f001b edx=9f3e001a esi=0017db08 edi=00000000
eip=7c902f48 esp=00129390 ebp=0019f920 iopl=0         nv up ei pl zr ac po nc
cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00000252
ntdll!RtlpInterlockedPushEntrySList+0x19:
7c902f48 75f1            jne     ntdll!RtlpInterlockedPushEntrySList+0xc (7c902f3b) [br=0]
0:000> !analyze -v
*                        Exception Analysis                                   *
*** ERROR: Module load completed but symbols could not be loaded for SALAMAND.exe
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for salrtl.dll -
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for tortoisesvn.dll -
FAULTING_IP:
ntdll!RtlpInterlockedPushEntrySList+19
EXCEPTION_RECORD:  ffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 7c902f48 (ntdll!RtlpInterlockedPushEntrySList+0x00000019)
   ExceptionCode: 80000003 (Break instruction exception)
  ExceptionFlags: 00000000
NumberParameters: 3
   Parameter[0]: 00000000
   Parameter[1]: 9f3f001b
   Parameter[2]: 9f3e001a
DEFAULT_BUCKET_ID:  HEAP_CORRUPTION
PROCESS_NAME:  SALAMAND.exe
ERROR_CODE: (NTSTATUS) 0x80000003 - {EXCEPTION}  Breakpoint  A breakpoint has been reached.
FAULTING_THREAD:  00000dc4
LAST_CONTROL_TRANSFER:  from 7c932124 to 7c902f48
STACK_TEXT:
00129394 7c932124 0024da78 00000000 00150000 ntdll!RtlpInterlockedPushEntrySList+0x19
001293cc 7c931c7c 00000000 00000000 00000000 ntdll!RtlpLowFragHeapFree+0x384
00129490 7c801be6 00150000 00000000 0024da78 ntdll!RtlFreeHeap+0x55
001294f4 7c801d6e 7ffdfc00 00000000 00000000 kernel32!LoadLibraryExW+0x1e9
00129508 7c801da4 0052e658 00000000 00000000 kernel32!LoadLibraryExA+0x1f
00129524 0040671c 0052e658 00000111 00000000 kernel32!LoadLibraryA+0x94
WARNING: Stack unwind information not available. Following frames may be wrong.
00129c20 0048fbb4 0012f274 0103b218 00000000 SALAMAND+0x671c
0012f1ec 00509a52 00000113 000003ad 00000000 SALAMAND+0x8fbb4
0012f20c 7e418734 000202b2 00000113 000003ad SALAMAND+0x109a52
0012f238 7e418816 005099fb 000202b2 00000113 user32!InternalCallWinProc+0x28
0012f2a0 7e4189cd 00000000 005099fb 000202b2 user32!UserCallWinProcCheckWow+0x150
0012f300 7e4196c7 0012fe90 00000001 0012fee4 user32!DispatchMessageWorker+0x306
0012f310 004c413c 0012fe90 00320038 00152343 user32!DispatchMessageA+0xf
0012fee4 004c496c ffffffff 00000000 773d0000 SALAMAND+0xc413c
0012ff24 0050c056 00400000 00000000 00152343 SALAMAND+0xc496c
0012ffc0 7c816fd7 00320038 00350030 7ffd9000 SALAMAND+0x10c056
0012fff0 00000000 0050bf22 00000000 00000000 kernel32!BaseProcessStart+0x23
STACK_COMMAND:  ~0s; .ecxr ; kb
FOLLOWUP_IP:
SALAMAND+671c
0040671c 8bd8            mov     ebx,eax
SYMBOL_STACK_INDEX:  6
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: heap_corruption
IMAGE_NAME:  heap_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
ADDITIONAL_DEBUG_TEXT:  Enable Pageheap/AutoVerifer
PRIMARY_PROBLEM_CLASS:  HEAP_CORRUPTION
BUGCHECK_STR:  APPLICATION_FAULT_HEAP_CORRUPTION
SYMBOL_NAME:  heap_corruption!heap_corruption
FAILURE_BUCKET_ID:  APPLICATION_FAULT_HEAP_CORRUPTION_heap_corruption!heap_corruption
Followup: MachineOwner
Hi Half-Death, you should really install nightly build of Tortoise SVN, because version 1.4.4 is faulty and was fixed in r9915.
Please look at http://forum.altap.cz/viewtopic.php?p=9882#9882
