Listing path <path>, press ESC key to cancel ENDLESSLY
noetus
Post by noetus »
I have a shortcut to Altap Salamander in my "Startup" folder. Often when the machine boots and Salamander starts there is a long thin window or dialog box which displays the message "Listing path "<path_name>", press ESC key to cancel..." which WON'T GO AWAY. It just sits there. Pressing the ESC key has no effect. Trying to close the window has no effect. The only thing which has any effect is shutting down Salamander (the annoying window then hangs around for a second or two longer than Salamander itself) and then restarting it again, which always seems to work. But this is clumsy and it's either a bug or I have a setting wrong somewhere. What to do?
cincura.net
Post by cincura.net »
When you press Esc more times, are you asked about terminating listing? If you wait some time (without pressing anything) does the listing finish? Propably is you computer under load.
Jiri {x2} Cincura
Is it possible that, when the AS configuration was saved, in one of the panes was a directory listing of a network resource/drive?
noetus
Post by noetus »
Hi, thanks for the replies!
No, I am pretty sure it is nothing to do with the load on the CPU. The CPU can be at idle for tens of minutes, and the message sits there. I can press ESC as much as I want, and nothing happens. Trying to close it does nothing, as well. Sometimes this happens when I switch drives, but as I don't have any network shares on this machine, it can't be that. And I can continue to work with Altap if I want - I can move the main window away from under the dialog box and continue working, switching directories, copying, etc, and the message stays on my desktop.
I have found one synchronization problem in this code. I have fixed it, please try fixed version and let me know if it works or not. Thanks!
Download it from: http://www.altap.cz/fix25/as25fix2.zip
Installation: just unpack salamand.exe to Altap Salamander 2.5 installation directory (overwrite original salamand.exe).
Peter, mozno by bolo rozumne tieto "fix" verzie aj identifikovat, aby sa v pripade inych problemov vedelo s akou verziou ma clovek do cinenia.
Napriklad: "Altap Salamander 2.5#2"
Salamand.exe contains build time, so there is no problem with identification.
Look at menu Help > Report Bug, the Built item.
