				PREVIEW: Delphi Conversion of the SDK
				Posted: 01 Jun 2007, 13:16
				by jomanto
				Hi folks,
things went well and faster than i thought so that I can already announce
the first preview of the Delphi version of the headers.
I'm still working on the conversion of the demoplug plugin to get things
started as easy as possible.
Feel free to test things by yourself. It should be possible to write basic
plugins for testing.
Critics, basic error reportings, etc. are very welcome!
				Re: PREVIEW: Delphi Conversion of the SDK
				Posted: 05 Mar 2010, 15:31
				by stepand76
				Attached is an updated Delphi version of SDK for Altap Salamader. It corresponds to version 2.53 (PB 44). It contains only conversion of headers, not comments, resources etc. (you can find comments and additional information in the original Altap Salamader SDK).
Notice: I use this SDK for only for my own plugins, mostly viewers, so I cannot guarantee the headers for file system, archivers, thumbnails etc. Good luck
				Posted: 28 Mar 2012, 08:27
				by darilek
				Hello,
please, can You post sample code with plugin initialization (so it can be detected and loaded by Salamander) developed in this converted SDK?. I can't create a working version
Thanks
				Posted: 28 Mar 2012, 09:44
				by stepand76
				I use this SDK for all of my plugins. Most of implementation is shared between them. So it is written very generic. I'm not sure if it would be helpful for you...
				Posted: 28 Mar 2012, 09:50
				Please consider using free
Visual C++ Express for a new projects. It is recommended way how to build Altap Salamander plugins, including x64 versions.
Microsoft Visual Studio 2008 Express Editions with SP1:
http://www.microsoft.com/download/en/de ... x?id=14597
				Posted: 28 Mar 2012, 10:56
				by darilek
				Hello Jan,
I'm currently writing in Visual C++ 2010
 My plugin implementation is relative easy and almost done, but I'm not a big C/C++ fan (specially in UI development) ... so just trying another way
BTW: Lazarus/FreePascal can compile x64 code and provided "Delphi SDK" is compatible
				Posted: 28 Mar 2012, 11:39
				OK
Does Lazarus/FreePascal work with Delphi conversion of AS SDK?
				Posted: 28 Mar 2012, 12:36
				by darilek
				Yes it does. I've created sample project with those converted files and it compiled succesfully. FreePascal knows Delphi syntax dialect.
But I can't get to work sample with basic exported functions consumed by Altap Salamander - SalamanderPluginEntry(), etc.
				Posted: 28 Mar 2012, 13:02
				by stepand76
				Please post your email address here. I will send a sample code to you.
				Posted: 28 Mar 2012, 14:14
				You can also use Private Message for email exchange.
				Posted: 28 Mar 2012, 16:41
				by darilek
				Contact sent in private message. Thanks!
				Posted: 10 Feb 2013, 10:35
				by Raptor
				Any chance to get updated Delphi SDK for the latest AS version? Or there is no need to update existing one?
				Posted: 26 Sep 2013, 21:08
				by costa
				I would be interested in the update as well.
