vili
Post
by vili » 28 May 2007, 15:47
If you sort the found files e.g. by Date, it only goes from the oldest to the newest. Any way to reverse the sorting?
Vili
k0nelupy
Post
by k0nelupy » 28 May 2007, 16:30
once again Ctrl+F5 or in menu Left(Right)/ Sort By /Time
arrow alongside icon has only one direction
I think this is little mistake
Guest
Post
by Guest » 28 May 2007, 16:37
I am sorry this is in panel in find dialog I don't know.
You may somewhere create Crtl+S Shortcuts for all files Ctrl+A.
vili
Post
by vili » 28 May 2007, 17:00
k0nelupy wrote: once again Ctrl+F5 or in menu Left(Right)/ Sort By /Time
It works in the MAIN window that you wrote. BUT: it does not work in the FIND window (after Alt+F7).
Vili
Posts: 1471 Joined: 10 May 2007, 16:08
Post
by Ether » 28 May 2007, 18:54
Hey Vili,
you're right - I tried it and in the Find windows sorting works only in one direction. That's clearly a bug, nobody can really mean or understand this as a feature
Posts: 5232 Joined: 08 Dec 2005, 06:34
Post
by Jan Rysavy » 28 May 2007, 19:16
Not supported yet, moving to feature requests.
