Total Commander Proxy Plugin
Re: Total Commander Proxy Plugin
Request for a new function
Please read the following post: http://forum.altap.cz/viewtopic.php?f=4&t=4492
Thanks
McL
Thanks
McL
LinkInfo + TCTorrent is OK (thx very much!!), but:
Excellence 1.20is taking AS down (like "alternative viewer on *xls file).
I dont know what to do with Imagine Version 1.0.7 - isnt listed in Alternative Viewers for me.
uLister + Text Search + Document Converter 2.0.0 is making this error:
- Outside_In_dlls_not_found.jpg (9.24 KiB) Viewed 79414 times
No plans to add this feature at the moment, sorry. Does TC have this functionality?McLion wrote:Request for a new function
Thanks
McL
For some reason generates exception on load, might take a look at it in future. Thanks for report.fraktik wrote:Excellence 1.20is taking AS down (like "alternative viewer on *xls file).
Works for me, but you need to associate it as (alternate) viewer manually in the Viewers & Editors section.fraktik wrote:I dont know what to do with Imagine Version 1.0.7 - isnt listed in Alternative Viewers for me.
The plugin does not work on its own, you need to install additional plugins from the Oracle website, see the Installation section of the readme.html file included in the plugin's zip archive.fraktik wrote:uLister + Text Search + Document Converter 2.0.0 is making this error:
I wasnt able to find him there, so i cant assiciate him.manison wrote:Works for me, but you need to associate it as (alternate) viewer manually in the Viewers & Editors section.fraktik wrote:I dont know what to do with Imagine Version 1.0.7 - isnt listed in Alternative Viewers for me.
OK, thx for reply - i was lazy.manison wrote:The plugin does not work on its own, you need to install additional plugins from the Oracle website, see the Installation section of the readme.html file included in the plugin's zip archive.fraktik wrote:uLister + Text Search + Document Converter 2.0.0 is making this error:
I don't know since I am not using TC.manison wrote:No plans to add this feature at the moment, sorry. Does TC have this functionality?McLion wrote:Request for a new function
Thanks
McL
I just felt that it would be nice to have slow plug-ins like the oilister preloaded on startup to speedup things a bit.
@manison: Can you please look why this lister plugin can't work with your wrapper: http://www.totalcmd.net/plugring/decftumb.html (decFastThumbs)
edit: please ignore this post - I had trouble with showing thumbnails and desperately searched for solution at wrong place
For clarification: Although WLX plugin, it's not actual "lister" (does not list content of files in separate lister window). Rather it's thumbnail provider plugin and those are not supported by TC Proxy (yet).otrov wrote:@manison: Can you please look why this lister plugin can't work with your wrapper: http://www.totalcmd.net/plugring/decftumb.html (decFastThumbs)
manison
It is a pity that the plugin is not suitable for the latest version of AS 3.0 beta 1.
Do you plan to update plugin?
I updated Total Commander Proxy Plugin for the latest Altap Salamander 3.0 beta 1.
The 64b version is also available. You have to match AS bitness with TC Proxy bitness and actual TC plugin bitness (AS 32b + TC Proxy 32b + WFX/WCX/WLX 32b or AS 64b + TC Proxy 64b + WFX/WCX/WLX 64b).
Please note that the version was not thoroughly tested so feedback and suggestions (especially for the 64b version) are welcome.
Download TC Proxy for AS 3.0 b1
I tried your Proxy plugin with Media Audio 0.78 beta for TotalCMD (http://en.totalcmd.pl/download/wfx/Ext/Media_Audio) to get the files to/from my new Android phone (which has no Mass Storage support).
It was installed correctly and file browsing worked OK. But when I tried to open a picture on my phone, an error occurred that it cannot be opened. I move to another picture in different folder of my phone. After pressing F3, Salamander freezed.
I didn't know what was happening. After while I saw that system behaviour is strange and I hit the reset button.
Salamander started to delete entire C: disk! It seems that it wanted to clear temporary files used by the plugin or viewer, but instead of them, it started from the root directory on C!
At least, I saved a big portion of my user folder by hitting that reset button.
The half of Program Files and other folders are gone (that's not so bad, I "just" need to reinstall the system), but one user profile was completely deleted from users.
Data couln't have been restore by using Undelete plugin. First of all, the Undelete plugin was deleted as well, and then, the recovered data only contained zeros.
Anyway, there's something wrong about the way how Salamander deletes it's temporaty data. Or is it the combination of Proxy plugin with Media Audio 0.78 beta plugin?
It seems like problem with Total Commander Media Audio plugin. We have no other report of such problem in Salamander and we didn't change this code path for years.
What Windows version do you use? Do you start Salamander "As Administrator"?
I am using 64bit Win7 Ultimate, and yes, I used admin account. I have UAC enabled, but I ran Salamander as admin because I was trying to copy this plugin files into Program Files folder.
I will try to reproduce this problem on VMware Windows 7 image with attached debugger. I will let you know.
Another question: what Salamander version do you use?
