New Limitation when Installing 2.5
Posted: 02 May 2007, 11:43
Hi guys,
I just installed 2.5, and got through an annoying limitation that just appeared: your cannot install it any more in the same directory as the previous version.
This is a pain: I have moved the shortcuts to Salamander into non-default places in my start menu, and it means I would have to update my shortcuts for each new installation. I worked around it, renaming the install directory before installing, and then removing the old version manually, on the disk and in the registry. Could you:
1. At least, allow installing in the same directory, as before.
2. If possible, handle the upgrade process in the installer (copying the old configuration, importing registration keys, etc.)
Thanks for the good work, anyway.
BTW, do you guys have this incredible summer weather we have in Paris for now one month? The earth global warming is no joke, at least for us...
