MP3 Tag Editor & Renamer
Posted: 19 Apr 2007, 20:16
by Eric
Following functionality would be great (ex.):
1. Selecting Files or Directory
2. Open Mp3 Editor (Files are shown like in the Renamer PlugIn)
3. Possibility to set tags for one or multiple selectable files
4. Possibility to rename files with help of pattern and MP3 tags
and more
Thanks
Posted: 19 Apr 2007, 23:12
by th.
I suggest to use MP3Tag (
http://www.mp3tag.de) for these functions. Just put it in the user menu.
Posted: 19 Apr 2007, 23:31
by Eric
Thanks, seems to be a great tool.
Better than ID3renamer.
This converted to a salamander plugin
Re: MP3 Tag Editor & Renamer
Posted: 04 Jul 2026, 12:18
by StevaHong
If Salamander is choking or throwing an error on specific MP3 files when trying to read them (especially when loading the metadata columns or using the file viewer plugin), it's almost always due to corrupt or malformed ID3 tags. Before looking for a deeper bug in the manager itself, it's worth checking if the files themselves are the culprit. You can use a quick web editor like
https://editmp3tags.com/ to open one of the problematic files, clean up or strip the tags, and see if Salamander handles it fine after that.
