FTP-Plugin - viewing folder with too many files
Posted: 24 Jan 2006, 13:52
by Guest
when browsing a FTP-folder with too many files, the view gets weird
message: unable to parse listing of files and directories from server. only plain text of listing will be displayed in panel
Re: FTP-Plugin - viewing folder with too many files
Posted: 24 Jan 2006, 14:28
by Petr Solin
I believe that problem is somewhere else, e.g. unsupported month names. Please send me your listing by email (petr.solin at altap.cz) (click right button in panel > Show Raw Listing > Save As). Or if you cannot send it (contains sensitive data), just write me, I let you know how to find text line which causes this problem.
Posted: 24 Jan 2006, 15:08
by Guest
Petr Solin wrote:I believe that problem is somewhere else...
you should be right cause it´s in another FTP-Folder too. there are 6 files only. i think now thats a problem of the server (i think its an apache) itself. here´s the problem i think:
drwxrwxrwx 2 fx y 12288 Jan 19 19:45 .
drwxrwxrwx 3 fx y 8192 Jan 4 07:25 ..
-rw-r--r-- 1 fx y 621 Jan 13 20:27
Bx@x.de-13012006
-rw-r--r-- 1 fx y 1919 May 17 2005 BxYx_
xYx@xYx.de-17052005
-rw-r--r-- 1 fx y 1172 Jan 19 19:45
Bx@x.de-19012006
-rw-r--r-- 1 fx y 786 Jan 9 16:42
Bx@x.com-09012006
-rw-r--r-- 1 fx y 420 Jan 13 22:49 Bx_-13012006
-rw-r--r-- 1 fx y 527 Jan 13 22:50
Bx.x@x.de-13012006
as you can see there is a file without any filedates/rights. or so the interpreter lists the file atleast. don´t know how it came to this. all the files were created using PHP. so i think UNIX doesn´t like the file.
in total commander i can´t delete or copy this file. so i think its the file´s fault.
Posted: 24 Jan 2006, 15:50
by omega
doesn't
xYx@xYx.de-17052005 belongs to -rw-r--r-- 1 fx y 1919 May 17 2005 BxYx_ ?
Posted: 24 Jan 2006, 16:16
by Guest
yes i think so. but SS lists that as 2 files.. (?)
could be a parse-failure. i don´t know.
Posted: 24 Jan 2006, 16:46
by Petr Solin
OK, it seems that end-of-line characters (CRLF) are in filename. I need raw listing to check what precisely happened. Please email me that file packed to ZIP archive (or other) -- I just want to protect it from modifications by email servers.
P.S. I don't care if you are registered user, you may be just evaluating our product.
Posted: 25 Jan 2006, 12:28
by Seelenquell
ok i´ve sent you the mail with the ZIP.
thank you in advance.
Posted: 25 Jan 2006, 13:37
by Petr Solin
I have it, thanks.
It really contains filename with CR+LF characters. I can test it here on our linux test server (I created such filenames), but unfortunatelly I have not found any way how to work with such files over FTP protocol.
I have tried couple of other FTP clients and they also cannot work with such files. So sorry, I have no solution for you.
Posted: 25 Jan 2006, 14:53
by KNUT
Petr Solin wrote:It really contains filename with CR+LF characters
unbelievable......................???
Posted: 25 Jan 2006, 15:00
by Seelenquell
ok thats not a big problem as this is a very very seldom thing. and furthermore, it is not a mistake by your extremly powerfull software.
will say, the source of this is the php-script who created the filename, right?
like i said, in total commander i can´t delete or copy this file(s) so why should it work here
its really no problem for me. but thank you very much for your quick reply and your tries to find the problem. keep up this good work.
