back/forward functions for folders
Posted: 23 Jan 2006, 13:50
by omega
I have a 5 button mouse (including the scrollwheel). If i use windows explorer i can use the 2 other buttons to go back/forward just like in a webbrowser.
Is it possible to implement this functionality in SS?
Re: back/forward functions for folders
Posted: 23 Jan 2006, 15:58
by KNUT
omega wrote:I have a 5 button mouse (including the scrollwheel). If i use windows explorer i can use the 2 other buttons to go back/forward just like in a webbrowser.
With my Microsoft IntelliMouse (optical, driver version: 5.20.413.0) it works like this :D
:shock:
Posted: 23 Jan 2006, 16:47
Back/Forward commands will be supported from SS 2.5 beta 11.
KNUT wrote:With my Microsoft IntelliMouse (optical, driver version: 5.20.413.0) it works like this :D
:shock:
Interesting...
Posted: 23 Jan 2006, 18:29
by omega
Mine is Microsoft IntelliMouse Optical and i just installed the 5.50.661.0 driver.
Doesn't seem to work like you described. Anyway glad this will be implemented in beta 11 :D
Posted: 01 Feb 2006, 15:35
by Josip Tosic
Maybe KNUT configured his IntelliPoint to send Alt+Left and Alt+Right?
IIRC, some older versions actually sent these key codes to applications. Gave up on IntelliPoint a long, long time ago. It's friggin' huge, and only has one decent option - scroll acceleration. I can live without it, though.
