Folders greyed out
Posted: 03 Apr 2007, 02:47
I had a very strange thing happen. Some of the folders in the root of C: were greyed out. When I clicked on them nothing happened. I couldn't navigate into the folders. If I did a right click and selected either open or explore windows explorer opened. Because explorer was able to open the folders I don't think it was a security problem. I changed the view options in IE to remove the check mark in "Hide protected operating system files" and to add a check mark in "Display the contents in system folders". This is a fresh install of Servant Salamander RC2 onto XP sp2. The Windows firewall is turned off. The PC does have Semantic Security Suite installed. I didn't see any programs that would lock out specific folders. If there was I wouldn't think I would be able to navigate folders in IE. (Which I was).
Any ideas?
Thank you,
Docfxit
Any ideas?
Thank you,
Docfxit
