Select the next 'n' items (or x MB)
Posted: 20 Jan 2006, 17:16
Suggestion for an new option:
_____________________
Select the next [ 20]
(o) Files / Steps [ 2]
( ) Folders
( ) Files & Folders
( ) Bytes
( ) MegaBytes
[ ] Remember last item
To select every second of the next 20 files
Select the next [ 695]
( ) Files /Steps [ ]
( ) Folders
( ) Files & Folders
( ) Bytes
(o) MegaBytes
[x] Remember last item
To select the next 695 MegaByte
and remember the last folder and file for the start of the next selection
(Or, if this is better to implement,
select as many as possible to NOT go over 695MB and remember the last folder only)
( ) Folders
( ) Files & Folders
( ) Bytes
( ) MegaBytes
( ) Folders
( ) Files & Folders
( ) Bytes
(o) MegaBytes
