He has problems to overwrite files or delete files. They seemed to be blocked.
If I use other FTP clients like Windows Explorer, I don't get these errors.
Here are some logs:
Delete File "Web.config" from 8.8.246.50
Host: "8.8.246.50", port: 21.
Log UID is 4, time is 06.02.2007 - 23:51:34.
(23:51:34): Using connection from panel...
(23:51:34): Deleting file "Web.config"...
CWD /wwwroot
250 CWD command successful. "/wwwroot" is current directory.
DELE Web.config
450 File "Web.config" can't be deleted.
(23:51:40): Deleting file "Web.config"...
DELE Web.config
(23:51:42): Deleting file "Web.config"...
DELE Web.config
(23:51:47): Connection was returned to panel...
Connecting to "8.8.246.50" (8.8.246.50) on port 21.
Log UID is 5, time is 06.02.2007 - 23:51:58.
220 Gene6 FTP Server v3.8.0 (Build 34) ready...
USER myuser
331 Password required for myuser .
PASS (hidden)
230 User myuser logged in.
(23:51:58): Logged in successfully, getting system information...
SYST
215 UNIX Type: L8
PWD
257 "/" is current directory.
Log UID is 7, time is 06.02.2007 - 23:52:27.
(23:52:27): Using connection from panel...
(23:52:27): Uploading file "Web.config"...
(23:52:31): Uploading file "Web.config"...
TYPE I
200 Type set to I.
PASV
227 Entering Passive Mode (8,8,246,50,85,166)
STOR Web.config
550 Cannot STOR.
150 Data connection accepted from 84.75.157.9:4549; transfer starting.
226 Transfer ok.
(23:52:49): Uploading file "Web.config"...
CWD /wwwroot
TYPE I
200 Type set to I.
PASV
227 Entering Passive Mode (8,8,246,50,216,177)
STOR Web.config
550 Cannot STOR.
(23:52:56): Connection was returned to panel...
(23:59:17): Uploading file "Web.config"...
CWD /wwwroot
TYPE I
200 Type set to I.
SIZE Web.config
213 0
(23:59:18): File "Web.config" was not uploaded completely (file size on server is not 2'118 bytes)...
(23:59:18): Uploading file "Web.config"...
SIZE Web.config
213 0
PASV
227 Entering Passive Mode (8,8,246,50,175,251)
STOR Web.config
550 Cannot STOR.
(0:00:19): Connection was returned to panel...
Eric
