Drap & Drop Directory Problem
Posted: 19 Jan 2007, 19:36
by deviationer
For some reason SS RC2 does not want to overwrite a directory all it wants to is merge.
Example:
Directory X on C:
Directory X on D:
Drag and drop X from D to C, does not overwrite, it merges the files.
Bug? Or did I turn on/off something by accident?
Posted: 20 Jan 2007, 00:24
It is not a bug, try Windows Explorer and you will find the same behaviour.
There is one related confirmation in Salamander:
Options > Configuration > Confirmations > Directories merge
Description:
http://www.altap.cz/salam_en/help/salam ... _cnfir.htm
