Improved Filter and Hide function
Posted: 18 Jan 2006, 22:24
Is there a quick way to disable
the "filter" and the "hide" option ?
I search for an short cut to see all files again,
i.e. enable
- "(.)Do not use filter"
and
- "Show hidden names"
at ones by an short cut.
Or can we give short cut at our self to this functions in future ?
At most i needed often an option to disable the Filter quickly.
Even nicer would be a "toggle" function between
Are ther more suggestions on that options ?
i.e. enable
and
- Use Filter (don't show unwanted files)
and
- hide unselected nameCode: Select all
- "(.)Do not use filter" (show all files)
and
- "Show hidden names"Are ther more suggestions on that options ?
