change default for Change Case command or allow user macro
Posted: 10 Jan 2007, 22:31
Whenever I use the Change Case command it is always to convert my selection to upper case only. Can I either make that the default when the command is opened or is there any way to create a user macro so with a keyboard shortcut I can change the case to upper case only ?
