Support for Carbonite context menu
Posted: 06 Jan 2007, 06:03
by MikeyP
I just installed Carbonite, the online backup software. It adds a right-click context menu to Explorer that allows you to choose whether to back up a file or not. Unlike other right-click context menu add-ons, the Carbonite context menu does not appear in Servant Salamander 2.5 RC2 on WinXP SP2.
Any ideas why?
thanks!
-MikeyP
[/url]
Posted: 06 Jan 2007, 17:29
by zarevak
Hi, does the Carbonite context menu works in open/save dialogs of Notepad/Word/... and other programs? Some context menu extension can restrict themselves to just explorer.exe process.
Posted: 06 Jan 2007, 18:32
by MikeyP
Ah ha, no, the Carbonite context menu does _not_ appear in File Load/Save dialog boxes. So it appears you are correct, Carbonite must restrict itself to the Explorer.exe process. I wonder if I can change that in the registry?
thanks for your quick reply!
-MikeyP
