				REQ: Desktop link in Change Drive Menu
				Posted: 11 Dec 2005, 15:40
				by Skrzat
				Pleas add the shortcut to Desktop folder of current user in Chenge Drive menu.
				Posted: 11 Dec 2005, 20:48
				by Sinaptik
You can add this folder with the Hotpath function.
In Ť Configuration ť -> Ť Hot Paths ť.
				Posted: 12 Dec 2005, 10:42
				by KNUT
				Sinaptik wrote:You can add this folder with the Hotpath function.
Yes, but the Hot Paths are all occupied
I would also like to have the "Desktop" in the "Change Drive menu"!
				Posted: 13 Dec 2005, 15:05
				by crystalidea
				There's also a good idea to view current user's recycle bin in the panel. Options to delete forever or restore will be great too.
				Posted: 13 Dec 2005, 16:27
				We are working on a new
Folders plugin which is intended for folder browsing (Desktop, Control Panel, Printers, Tasks, etc).
Folders plugin has been postponed due to the release of Servant Salamander 2.5.
Change Drive menu: structured Hot Paths are listed on our
roadmap.
Screenshot of semifinished Folders plugin:
				Posted: 04 Aug 2006, 10:24
				by hrc
				I was wanting to post the same feature request; was thinking of a solution where the menu-group was configurable like the the hot-path's.
Actually I don't understand why the documents link is there and the desktop isn't - seems to me like it was a "forgotten" feature.
/hrc
BTW. I can't figure out the attribute sort order in the list view (detail view). I know that there's 4 different pieces of information in that column, but why not just sort it as a string? It might not be easier but at least I'll understand the sort order.
				Posted: 04 Aug 2006, 10:36
				hrc wrote:BTW. I can't figure out the attribute sort order in the list view (detail view). I know that there's 4 different pieces of information in that column, but why not just sort it as a string? It might not be easier but at least I'll understand the sort order.
Please post this as a new feature request. Look at forum rules:
http://forum.altap.cz/viewtopic.php?t=55
