Saving et retrieving directory
ADB
Post by ADB »
Hi
I remember that in earlier version, Salamander was opening itself on the last directories I had left open bzefore to close it.
Presently, I don't find this feature or the way to indicate it to Salamander.
Could you explain me?
Thks
ADB
PS: anyway, this is the best explorer I found in the world. And I'm used to it.
Arnaud Dupin de Beyssat
Please, check if Options > Configuration > General > Save configuration on exit is turned on.
You should also check whether you have a file called config.reg in Salamander's install directory. If you do, you need to rename it.
