strange single drivebar bug in rc2
Posted: 30 Oct 2006, 21:48
by LioMajor
i've got a real strange bug in using single drive bar
all driveletters are collapsed , even the first C: is unreadable or clickable
using two drivebars works properly
Posted: 30 Oct 2006, 21:57
Try clear this option: Options > Show > Lock the Toolbars.
Then you should be able to set toolbar size.
Posted: 30 Oct 2006, 22:20
by LioMajor
thx, worked.
