Date inserted by hotkey
Georgd
now using a separate tool
Post by Georgd »
I'm not needing that function any more, as I'm now using a separate tool called HotKeyz that works windows-wide (=in all apps), is quite light wight and also supports other functions (e.g. open calculator, create new outlook calendar entry, switch off the monitor - all with one single hotkey). Help and Download at http://www.skynergy.com/hotkeyz.html The entry details are:
Category: HotKeyz commands
Command: Paste
Hotkey: CTRL+ALT+D
Parameter: [DATE_CCYY-MM-DD]
I've a second entry with time, it's started with CTRL+ALT+F and has the Parameter [DATE_CCYY-MM-DD] [TIME_HHmm]
Cheers, Georg
Using Salamander since v 1.52
azaz44
Re: Date inserted by hotkey
Post by azaz44 »
Hotkeyz works like a charm, thanks a lot.
Georgd
Post by Georgd »
azaz44 wrote:Hotkeyz works like a charm, thanks a lot.
Welcome :-)
