Corrupt Archives
Posted: 21 Oct 2006, 05:15
I have run across some corrupt archives. And have had problems extracting the contents using Servant Salamander.
Servant Salamander will only extract the "good" files and will not partially extract the "bad" files. The CRC is wrong on these files, however, when I go use the undelete function of SS, I find the file there and copy it else where... 95 percent of the the time this file is 100 percent there even though the CRC is wrong. It would be nice if I was asked if I want to save the partially recovered file -- i.e. "Only 98% percent of the file was able to be extracted would you like to save the extracted file?" This would save some steps to recover the partially recovered file in the archives.
Current output is says something about wrong password? These archives are not passworded. A CRC error doesn't mean that the archive has a bad password as you cannot extract any of the file with a bad password. In fact if the password isn't supplied correct on a passworded archive you get the wrong password message in SS.
To me this is a bug. You should have the option of extracting the corrupted file from the archive for partial to full recovery.
Thank you,
George Worley
Thank you,
George Worley
