PictView: ScreenShot tool issues - suggestions
Georgd
Post by Georgd »
Moved from http://forum.altap.cz/viewtopic.php?p=6253#6253
"Screen capture" of PictView is currently not providing the tools that make the workflow really smooth. At the moment, I need 4 additional tools just to do ScreenShots. If PictView was able to do all 3 things mentioned below, I could work within one single tool :) and stay where I will manage the saved file...so I'm happy to hear from you what you think :)
1) WinSnap (http://www.ntwind.com/software/winsnap/) might serve as an inspiration with it's great feature "save as thumbnail" and "copy thumbnail to clipboard". Would be a tiny but nice addition smoothing the workflow of screenshots and maybe others as well (web page editing etc).
2) Moreover, I like the mode "Capture Windows/Object" of FastStone Capture http://faststone.org/FSCaptureDetail.htm as it allows to capture single GUI widgets (buttons, lables, panes,...) without any need to crop manually. Great when talking about errors in translation, layout etc. of software.
3) Both tools allow to capture a rectange and provide a magnifier area, so selecting the correct are is easy. This is way more efficient and intuitive than frist capturing, then zoom in, select -- which is quite hard when you have to scroll at the same time (image is heavily zoomed) -- and crop.
4) Very simple highlighting tools (rectangle, arrow, free hand) are usually needed to point to the issues one's writing about. IMHO they can be _really_ simple, some of FastStone Capture's tools are already too sophisticated, e.g. the "free hand drawing" tries to produce a polygone making it impossible to write with the Tablet PC pen :-( whereas the highlighting tool is really nice (UI and workflow). Could be used as inspiration. For really nice annoations, the Microsoft Snipping Tool might serve as inspiration, see description at http://www.microsoft.com/windowsxp/usin ... mspx#EQCAC but from my point of view, this is out of Salamander's scope -- only mentioned due to the UI and possibilities.
/Georg
Using Salamander since v 1.52
drumut
Post by drumut »
i believe that if crop tool would integrated in picture viewer plugin that would be cool.
drumut wrote:i believe that if crop tool would integrated in picture viewer plugin that would be cool.
There already is Edit > Crop command in the PictView plugin.
konelupy
Post by konelupy »
I need some like "save as thumbnails" or "copy thumbnail to clipboard" too
when we have windows thumbnail now.
But not only for Pictview - I prefer for all plugins together
Georgd
Re: PictView: ScreenShot tool issues - suggestions
Post by Georgd »
For me, this does not have priority any more and may be closed. For the last 2 years, I used PictView only a few times for screenshots as its workflow requires much more clicks etc. than my other screenshot tools, especially if I need to annotate (add a rectangle or the like). I use ALT+INS for quickly copying the screenshot target path from salamander to the save dialog file field of the screenshot tool - that's fine for me.
