Funny Change of Folder after invoking a .ifo file
Posted: 29 Sep 2006, 18:55
by Marc
every time I start a .ifo file placed in a folder which name contains a underscore, the player (media player classic) gets started, but Salamander jumps back to the default directory instead of staying into the video-dir.
Starting a .vob file in the same dir does not produce this effect.
Checked the registry but .ifo and .vob do have the same settings
(open\command = "C:\Programme\Media Player Classic\mplayerc.exe" "%1")
any ideas on that?
best regards,
Marc
Posted: 01 Oct 2006, 14:11
Marc, this problem will be fixed in Servant Salamander 2.5 RC2.
Bug was introduced in SS 2.5 RC1: some system events were wrongly interpreted as disk (volume) removal.
SS 2.5 RC2 will be released this month. Could you please then confirm the problem is solved?
Posted: 28 Oct 2006, 10:37
by grizzly
the same "problem" (better: "funny behaviour") occurs on my system.
To check DVD data located on the hard drive I usually doubleclick VIDEO_TS.VOB. This starts the Windows Media Player. When closing the Media Player Servant Salamander has jumped back to C:\.
The DVD data contains video streams recorded using a TV card, arranged using GUI for DVDAuthor - but I don't think that has any influence.
I installed Salamander RC2 today, but the "Problem" remains. Windows Media Player starts up, and before it actually starts playing the video data, Salamander already jumps to C:\.
It happens for VOB and IFO files.
It does not happen, if Media Player has been running already.
I use Windows MediaPlayer 10 on a Windows XP Prof.
Regards
Michael
Posted: 28 Oct 2006, 10:45
Michael, we will definetely look at this problem! Could you test a special debug version of Salamander for us?
Posted: 28 Oct 2006, 11:01
by grizzly
No problem. Hand it over...
Michael
Posted: 29 Oct 2006, 11:11
by Marc
As requested, I tried it with RC2.
Same result :(
Posted: 06 Nov 2006, 15:58
by Petr Solin
It's fixed now. Thanks to Michael (grizzly) for testing! It will be available in version 2.5 RC3.
