Descript.ion support
Posted: 06 Sep 2006, 13:20
An search about "Descript*ion" founds nothing? Even not in the ALTAP Roadmap (updated 05/26/2006)
Is no one intressted to use Decriptions?
Feature request: native use of Descript.ion within Salamander
Or know any one an stand alone tool i can use with Sala? Please?
Long time i didn't know what to do with this 'descript.ion's.
I used to use text files, named like the file i wanna to describe.
And i will do so in future... for longer text.
like:
Blat.exe
Blat.txt
xyz.exe
xyz.txt
But now i use descript.ion in Sala and after a few days of using i love it!
I have for ex. an folder with a many command line tools.
I had a lot of work to create text files with info what this exe or com does
An, i want call it "descript.ion handler", show me all files in an folder
and allow me to put an sentence as decription behind this file name.
Like:
Blat.exe
xyz.exe
DESCRIPT.ION
In the DESCRIPT.ION text file is an text like:
Blat.exe - Commandline eMAil tool
xyz.exe - will extract all boot images from...
See all the files in the folder.. and the DESCRIPT.ION file:
In this DESCRIPT.ION file are all file with name and an description about this file:
http://manpages.debian.net/cgi-bin/disp ... ormat=html
Descript.ion are also support in Monat:
http://www.leeholmes.com/blog/DESCRIPTI ... Part2.aspx
Here is an more advantage Description handler who use even plugins
to export some description automaticly:
http://www.totalcmd.net/plugring/FileDiz.html
What do you think?
Is DESCRIPT.ION support needed this days?
Will Altap Staff implement such a feature?
Will rose marry joe.. err, this is one another story, soon on Pro7.
like:
Blat.exe
Blat.txt
xyz.exe
xyz.txt
Like:
Blat.exe
xyz.exe
DESCRIPT.ION
Info about and example Descript.ion:Descript.ion is a standard used by many applications to save file and
folder descriptions. It creates a hidden file in the folder containing the file
or folder, with the name of the item and description. Descriptions will be
saved and thus appear on the next time you look at the folder with a
software that supports the standard.
What do you think?
