Checksum plugin
Posted: 18 Aug 2006, 16:03
Is it really necessary to have the header
included in every .sfv or .md5 file? I do not desire the header to be removed completely, I believe adding a checkbox "Enable/disable header" to the plugin configuration would be sufficient.
Thank you
; Generated by Servant Salamander, http://www.altap.cz
Thank you
