Automaticly rename doubles by copy/move
Posted: 11 Aug 2006, 23:42
An request to improve salamander:
While copy/moving files
it would be nice to
automaticly rename new files
if the name already exist
in the destination folder.
I think about an new button
in the copy/move dialog like [Rename]
Confirm File Overwrite
Overwrite
With
[Yes] _ [All] _ [Skip] _ [Skip All] _ [Cancel] _ [Rename]
and an new check box in the options.
The renaming could be simple (for manually modify later)
like
file.txt
file_00001.txt
or even
file.txt_00001
if this is easier to implement.
This would be usefull for merging folders.
Good would be an option to choose the renaming pattern like
( ) add _##### at the end of the double file
( ) put _##### at the front of the double file
The first option is for to sort selfsame files next to each other.
The second is for to put the double files at top of all others for to see what happend at easy.
What do you think about such a feature?
it would be nice to
Overwrite
With
like
file.txt
file_00001.txt
or even
file.txt_00001
