auto-scrolling function
Posted: 05 Jan 2006, 23:13
by honkponk
is there any opportunity to auto-scroll in the windows?
or would it be implemented in the next update.
btw i love 3 button mice without any wheel.
thx from germany
Posted: 06 Jan 2006, 08:35
Could you please more exactly describe this problem?
Servant Salamander 2.5 beta 10a doesn't auto-scroll panel on your computer whilst other applications scrolls fine?
Could you specify which mouse are you using, mouse drivers, Windows version?
Posted: 06 Jan 2006, 09:29
by skwire
Judging from what the OP said, he has a regular three-button mouse (no wheel) so I would think he's asking for functionality similar to what you get in a web browser where if you middle-click, you get the little up/down arrow graphic and can then move the mouse above or below said graphic to scroll up and down a page. Honkponk, is that what you're asking for?
Re: auto-scrolling function
Posted: 04 Feb 2006, 20:39
by jis
honkponk wrote:btw i love 3 button mice without any wheel.
Btw, 2 button mice with wheel can acts as 3 button mice, because you can click on the wheel... Why do you hate the wheel?
Posted: 05 Feb 2006, 14:45
by omega
Maybe he doesn't know the wheel can act as a 3rd button? OR he only wants to use his middle finger for activating auto scroll. OR he hates to move his index finger to the wheel
Anyway i just tested the auto scroll function in windows explorer. Doesn't work just only on webbrowsers.
