Find 'search subdirectories' off by default
Posted: 10 Jul 2006, 22:45
by johnd126
Could the next version please have an option to have 'Search Subdirectories' in the Find dialog UNchecked by default? 99% of the time I'm searching for text in a file (which works very well) and I know it's in one of the files in the current directory.
Posted: 10 Jul 2006, 23:29
Use the Find Options > Add Current / Manage to define your own Find settings.
Posted: 10 Jul 2006, 23:36
by johnd126
Jan Rysavy wrote:Use the Find Options > Add Current / Manage to define your own Find settings.
Doesn't that only work if I define a directory as well? I really want it to be the default always, for all time, forever, for every folder I want to search in.
(Don't get me wrong ... I'm really a great fan of SS ... I use it every day on two diffrent machines and tell everyone about it when I can.)
Posted: 11 Jul 2006, 09:22
johnd126 wrote:Doesn't that only work if I define a directory as well? I really want it to be the default always, for all time, forever, for every folder I want to search in.
Leave the Look in field empty...
Posted: 11 Jul 2006, 16:20
by johnd126
Brilliant! That's just what I wanted. :)
Thanks!
John
