Salamander opens in unavailable area
Posted: 06 Jul 2006, 14:54
by joachim.lang
I am using Salamander on a laptop with second monitor. The second monitor is number one and the laptop screen is number two. Salamander opens on screen two. When I use my laptop without the extra monitor, and I open Salamander, it opens in a region that is somewhere not visible. On screentwo, that is not avaliable. I can not get the window back. Other apps automatically display their window on screen one, if screen two is not available.
Regards Joachim
Posted: 06 Jul 2006, 18:43
by SvA
This is no solution to your problem, but a temporary workaround to bring the window back to the visible area.
First you need to determine the accelerator key your windows uses to initiate moving a window from the system menu. To do so, activate any visible window which is movable and has a system menu. Press ALT-SPACE to activate the system menu. Now note the underlined character in the menu item for moving the window (On my German system, this is 'V' from 'Verschieben'). Then close that system menu again.
Activate the invisible window, e.g. by selecting its button on the task bar. Press ALT-SPACE followed by the accelerator key you found in the preceding step. (The system menu probably wont be visible, but it still works.) Now press any arrow key. By doing so, the window gets attached to your mouse cursor. Move your mouse until the window is back on the visible desktop. Then click any mouse button to release the window.
Re: Salamander opens in unavailable area
Posted: 06 Jul 2006, 22:16
by ino
joachim.lang wrote:I am using Salamander on a laptop with second monitor. The second monitor is number one and the laptop screen is number two. Salamander opens on screen two. When I use my laptop without the extra monitor, and I open Salamander, it opens in a region that is somewhere not visible. On screentwo, that is not avaliable. I can not get the window back. Other apps automatically display their window on screen one, if screen two is not available.
Regards Joachim
check this thread:
http://forum.altap.cz/viewtopic.php?t=6 ... ht=monitor
Maybe it could help
