Page 7 of 14
Re: Total Commander Proxy Plugin
Posted: 04 Sep 2009, 11:22
wsorg wrote:Total Commander Proxy Plugin pro Altap Salamander does not work with new version Altap Salamander 2.52 Final.
It works fine, please use version for Altap Salamander 2.51 (AS 2.52 is backward compatible with 2.5 and 2.51 plugins).
Posted: 04 Sep 2009, 12:04
by wsorg
Thanks!!!
Yes really all works, but it is quite good to make the new version of a plugin.
Posted: 04 Sep 2009, 12:17
It would be great if Manison could update plugin description (compatible with AS 2.51 and further versions) and remove 2.52 beta 1 version (AS 2.51b1 just expired). That's all.
Posted: 04 Sep 2009, 21:47
by manison
Done. The
updated version is compatible with Altap Salamander 2.51 and later and also contains minor bugfixes.
Posted: 17 Sep 2009, 11:58
by gem45
Thanks for the information
CanonCam is functionally. it works great.
Thank you.
Posted: 01 Dec 2009, 18:41
by manison
New version of the Total Commender Proxy plugin is available for
download. This version includes a brand new Total Commander plugin installation wizard, implements the delete function for the file system plugins and also fixes some bugs. For the complete list of changes see the history.txt file included in the package.
Posted: 01 Dec 2009, 19:49
by vld
Very nice.
Is this still only compatible with Salamander v2.51 and newer?
Posted: 01 Dec 2009, 20:05
by manison
vld wrote:Very nice.
Should be compatible with 2.5+, however tested on 2.52 and PB38 only.
Posted: 01 Dec 2009, 20:21
by vld
Ran a quick test and appears to work with v2.5
Posted: 01 Dec 2009, 20:24
by manison
vld wrote:Ran a quick test and appears to work with v2.5
Thanks for the confirmation. BTW, any reason to stick with 2.5?
Posted: 01 Dec 2009, 20:43
by vld
actually I have 2.0, 2.5, 2.51, & 2.52 all in their own folders....just in case I find a glitch and want to verify with previous versions.
Posted: 01 Dec 2009, 20:59
vld wrote:actually I have 2.0, 2.5, 2.51, & 2.52 all in their own folders....just in case I find a glitch and want to verify with previous versions.
Posted: 09 May 2010, 15:39
by manison
New version of the Total Commander Proxy plugin is available for
download. This version fixes problem reported with NokiaFS plugin. Copying directory trees from local file system to the plugin should now work.
Posted: 12 May 2010, 07:28
by darilek
manison wrote:New version of the Total Commander Proxy plugin is available for
many thanks, i started using your proxy plugin with TC Syn2 lister plugin. I replaced AS internal viewer with this. It is fast, supports syntax highlighting, UTF8
Posted: 12 May 2010, 09:10
