Page 5 of 14
Posted: 22 Mar 2008, 15:16
by SvA
Thank you, manison, for this plugin. It works great for most wfx plugins.
I tested
Environment Variables 1.3.0.222v.
This plugin takes Salamander down (the process silently ceases to exest) whenever I try to navigate to the "Current process (Total Commander)" folder.
Is this a bug in the proxy or some dependency on TC in the wfx plugin itself? Is there anything you or altap could do about this? Especially the fact that Salamander vanishes without even displaying an indication of an error disturbs me.
I use AS 2.5 on WinXP SP2
Posted: 22 Mar 2008, 21:19
by manison
SvA, thanks for the feedback.
I downloaded the Environment Variables plugin and I have no problem with it. Can you please upgrade your Altap Salamander to latest version 2.51? It features improved error handling that could catch your problem. The behavior is as expected in Total Commander? Do you have any shell extension installed? If so, try to disable icon overlay handlers in Options > Configuration > Icon Overlays (only available in AS 2.51).
Posted: 23 Mar 2008, 19:08
by SvA
Thanks, manison, for your prompt reply.
I tested it with 2.51 -- with the same result. No debug information available. I even recorded the crash with Sysinternal's Process Monitor: nothing to be found that even remotely looks like a problem. When I press enter with the Current Process entry activated, Process Monitor records thread exits for Salamander's treads, followed by registry key closes and file closes and finaly process exit.
But then I stopped some other running apps and tried again (in order to get less background noise while recording. This time, the plugin worked!
I finaly could trace it back to the presence of Opera 9.2 in the system as an activated SVS virtual application. Opera does not even need to run, just the layer activated (i.e. visible to the system) in order to trigger the malfunction. So I guess it is not an issue with either of the plugins, nor with Salamander, but rather with my virtual application or the Software Virtualisation Solution itself. Since I rarely use that layer I am going to ignore the issue.
Thanks again for your assistence.
Posted: 24 Mar 2008, 16:40
by manison
SvA, thank you for the investigation.
Posted: 27 Mar 2008, 04:41
by Zero3K
When using the t-pot (
http://code.google.com/p/t-pot) filesystem plugin with it and copying a file off of the iPhone/iPod Touch, it displays a different Copy dialog than expected. Altap Salamander then becomes very slow.
Posted: 30 Mar 2008, 23:17
by manison
Zero3K wrote:When using the t-pot (
What copy dialog do you expect? Does Total Commander also slow down? I do have neither iPod nor iPhone and I cannot check this out.
Posted: 30 Mar 2008, 23:35
by Zero3K
manison wrote:Zero3K wrote:When using the t-pot (
1. I expect to see the Copy dialog that Altap Salamander uses.
2. No, Total Commander doesn't allow me to click in its window while its busy copying files.
Posted: 01 Apr 2008, 19:04
by manison
Zero3K wrote:1. I expect to see the Copy dialog that Altap Salamander uses.
The progress dialogs will be improved in a future version of the Proxy plugin.
Zero3K wrote:2. No, Total Commander doesn't allow me to click in its window while its busy copying files.
Salamander's main windows should be disabled as well during the copy operation. I'll check this out together with the progress dialogs. Thanks.
Posted: 23 Apr 2008, 17:49
by Zero3K
So, did you fix those problems yet?
Posted: 26 Apr 2008, 14:23
by manison
Zero3K wrote:So, did you fix those problems yet?
No, due to the lack of my free time these problems have not been fixed yet.
Re: PREVIEW: Total Commander File System Proxy Plugin
Posted: 31 Jan 2009, 08:06
by ino
manison wrote:
Download Total Commander File System Proxy Plugin from the project page.
manison, could you please update your tcfs.spl plugin to latest AS2.52b1, I miss that a lot
Posted: 01 Feb 2009, 19:34
by manison
ino wrote:manison, could you please update your tcfs.spl plugin to latest AS2.52b1, I miss that a lot
Thanks for your interest. Please
check out the updated version.
Posted: 01 Feb 2009, 20:11
by ino
manison wrote:ino wrote:manison, could you please update your tcfs.spl plugin to latest AS2.52b1, I miss that a lot
Thanks for update, it works perfectly!
Posted: 01 Feb 2009, 20:23
by JohnFredC
I just downloaded AS2.52b1 and tried to add a few TC wfx plugins with the latest version of tcfs.spl referenced in the above post.
Salamander refuses to add any of the TC wfx plugins I have tried. It wants an associated language (.slg) file which, of course, the TC wfx plugins do not have.
I know I had this working in the past. What am I missing?
The .wfx and .spl files are properly in each plugin folder.
Thanks in advance.
Posted: 01 Feb 2009, 20:49
by ino
JohnFredC wrote:Salamander refuses to add any of the TC wfx plugins I have tried. It wants an associated language (.slg) file which, of course, the TC wfx plugins do not have.
Extract all files properly from tcfs.zip- there is folder "lang" which contains the missing file english.slg.
tcfs.zip contains following:
lang\english.slg
history.txt
readme.txt
tcfs.spl
